Which Type R's to get with JL 500/1 amp? 1221D or 1241D
Username: Brokeyaankles
hey I just got a JL 500/1 amp and plan on getting a couple 12" Alpine Type R subs but I dont know whether to get the 1221D's or the 1241D's....can anyone help me out?
thanks
Username: Stephenc8869
Post Number: 24
what r the specs on the amp? ____@4 ohms?_____@2ohms? _____@1 ohm?
ThatGuyYouKnow
Stephen This may sirprise you BUT JL Audio has real flexability, all RMS
500W @ 4ohm 500W @ 2Ohm 500W @1.5Ohm
and any other laod inbetween.
Post Number: 27
well in that case i would get the dual 2 ohm versions. and wire it like the 2nd diagram
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+2+ohms+x+2&image.x=22&image.y=8
