What is the Best Sound Quality Sub..
Username: Flyfishin4trout
Park City, UT USA
Post Number: 24
I have a Boston Acoustics Enclosure with 2 10's in it now that has the passive radiators. Wanted to get an idea of what you guys think about the box I already have and if its a piece then what type of sub should I get. All I care about is Sound Quality. I dont need to wake the neighbors anymore than I already do :0 The amp I have to push the sub is a US Amps de500. It says that it pushes 500 watts at 2 ohms but it sure seems pretty powerful maybe its got some extra giddyup to it. Thanks again for all the help I get here you guys are great.
Username: Slim
St.pete, Florida
Post Number: 72
theirs couple if build to specs from what i heard the idmax, re x's and brahma are some of the best including jl's also.
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 209
Bostons are great speakers for SQ. I ran the PROs in my last set up and loved it. I have also heard good things about the G5 series. So I would stay were you are. I am sure you will like it.
