Refurbished amps?
Username: Hiphopanonymous
Post Number: 163
I am planning on buying a new amp. Well, I should not say new, but a refurbished amp on ebay. Any of you had experience buying an amp off ebay? And did it perform just as well as a new amp?
Username: Carguy
Post Number: 600
Hey I wouldn't buy refurbished amps off eBay. It'll cost you more than a new one if it breaks down. Try your local shops for refurbs. However, new amps are a different story. I have bought new amps and so far they're great.
Username: Karthalin
Tacoma, WA USA
I bought a Rockford Fosgate Amp off of Ebay. It was to power 2 Lighting audio 12" subs, the subs asked for 250W RMS. The Amp was rated 300W RMS 900W max. The subs sound friggin awsome. Amp never broke down on me, always ran strong. I never got it tested to see the numbers though. Ownd it since May. Selling it now, want a sweet RF amp? :-)
Post Number: 165
thanks for the replies. no thx casey, i'm keeping an eye on an mtx amp on ebay.
Username: Smhuosrktays
Rochester, New York USA
Post Number: 15
I know I might be slammed for this, but I bought a refurb. sony amp off e-bay about a year ago, I listen to my music pretty loud sometimes, and I've never had one problem with it, infact, I have a whole sony system, and haven't had any problems.
Username: Carguy
Post Number: 618
Hey Keith, I wouldn't slam you for buying Sony. Just don't do it again! :-)
If your Sony amp is still working, be very glad you didn't have the problems others have, period.
