Speaker baffles
Username: Jwbulger79
Florida
Post Number: 74
http://www.crutchfield.com/S-4giEQ0VOxGp/cgi-bin/prodgroup.asp?s=0&cc=01&g=762&e st=&search=baffle
do these do anything? do they help out with bass? pretty cheap; would buy if they help at all. thanks.
Username: Carguy
Post Number: 621
Hey JW, they're mainly used to repel dirt and moisture away from your speakers. They will not give you a boost in bass.
If your car has water problem during rain, it might help protect it better.
Florida
Post Number: 75
right on. thanks isaac.
