How do you bridge a 2 channel amp?
Username: Bass_crazy
Odessa, Mo U.S
I dont know how to bridge a 2 channel amp so i can wire 1 sub up two it and win i bridge it will get have more power in the amp? and there is a mono button on it will that help too.
Username: Oleg
Santa Monica, CA USA
Post Number: 11
Each channel has a positive and a negative lead. If the amp is bridgeable, then you'll be able to connect your sub to the positive lead of one channel and then negative lead of the other channel. This will probably produce about double the power of 1 channel. Which amp is it? That way we can help you more.
Username: Oleg
Post Number: 12
Odessa, Mo U.S
its a older carver amp 90w per channel
Username: Oleg
Post Number: 34
Find out if it's bridgeable. If so just follow the instructions I've given you and you'll be good to go.
Username: Shit4brains
Australia
Do you also have to connect the positive & negative terminal that are not connected to the sub with a wire link?
Username: Oleg
Post Number: 56
you have to connect the pos and neg to the box's pos and neg and then to the amps pos and neg.
Username: Carguy
Post Number: 565
Whoa Phillips, you don't connect the terminals with a wire link. To bridge most 2 channel amps, take the pos from left channel and neg from the right channel. Use those 2 to connect your sub. Leave the other terminals alone.
Username: Oleg
Post Number: 61
What's a wire link anyway?
Username: Carguy
Post Number: 568
Not sure, I thought he meant using a wire to physically connect the unused terminals.
Odessa, Mo U.S
it has a mono button on it do i need to push it win a bridge it?
Username: Oleg
Post Number: 73
Isaac? I dunno about any mono buttons on amps. This one's on you.
