Overpowering / Underpowering
kklagge
I'm going to be using a Kicker KX650.4 to run my system (120x2 up front & 325x1(bridged) for a 12" sub).
I'm mainly interested in getting either CDT or OZ Audio components (or perhaps something else in the price & quality range that has a soft silk tweeter) so here's my newbie question:
I can get CDT CL-61a's for about $150 (90 watts RMS)
I can get CDT CL-62's for about $200 (150 watts RMS)
I can get OZ Audio 180CS for about $200 (100 watts RMS)
I don't want to overpower or underpower the components too much and since I'm on a fairly tight budget I don't want to spend more than I really need to.
So which of the above components would best suit my needs (they will be Xover somewhere between 80 -100hz)
Thanks for any input or suggestions
GuyFromMarz
CDT CL-62s sound great on 100 watts. they also sport a better quality crossover than the OZ audio set.
120w on comps might drown out the sub with 325w on it though.
