Quick ground question!
Username: Klone420
Post Number: 20
Is it alright to have two ground wires connected to the body at the same place? Or should they be seperated? They are two different amps.
Username: Carguy
Post Number: 708
Hey Andrew, as long as you have a good ground contact, you're fine. You might try getting a power distribution block for your ground and power wires. That way, with one wire, you can power 2 or more amps.
