I have two 2000watt audiobahn Alumq12 subs.My two amps are two 2000watt Pyramid subs. How do I wire them to my car? I have a sony head unit with three pre-outs and it has sub controls. Thanks alot ~heath
ok. run rcas from your HU to your amp. and a remote and then power from batt. and ground wire to frame. after that it depends on if the subs are dvc which im sure they are, and how low of ohms your amp can go. pyramid doesnt make anything great, so im not sure. ahh hell well say it 2 ohm stable. if your subs are 4ohmx2 than you will have to run them in a series, neg to pos, on both subs. if they are 2ohmx2 then run them the same way. i would look around and see if you cant get some better equipment imo. i imagine you are very green to car audio, just look around, thats all im saying.
