Like
Power question for speakers
Username: General
I have a bowick MA 150.2 rated @ 300 watts @ 4 ohms driving diamond audio M3 compents in the front... and CM3 coaxals in the back...
I resently bought a set of diamond audio 600a Hex series..
will i be able to run these news ones, and the old m3's... or will i hae to take out everything and just leave hex in the car ?
if anyone can help me, it would be appeciated
Username: Solacedagony
New Jersey US
Post Number: 101
Are you talking about running both sets of components from the same amp? Assuming you bridged your amp into two ohms and wired your sets in parallel to get the 2 ohm load, it would be possible. But should you? I'd say you would want a dedicated amp for each set of components you'd be running. Also, I don't know much about components, so I don't know how much running two sets would affect your sound.
(Sorry if I didn't answer the question, I wasn't quite sure what you were getting at.)
Username: General
well, that was kinda answering my question.. but really im looking for is my amp powerfull enough to run the hex 600a series
Facebook
Shop Related Deals
Directory
