Half-din dvd needed
I'm looking to put a dvd in my airplane. Full DIN will not fit. I can remote locate the dvd player but I need a motorized or non-motorized display head that will fit a half-din space. Any suggestions?
Try autotoys.com they'll have what your looking for.
Raul
in www.concept.com you can find the half din DVD player /mp3 player
Dee Johnson
I know it's a bit late, but try http://www.bigdaddyscooters.com/Description.aspx?ID=DVD-150
