Setting gains on a fosgate amp
Username: Heavyb
Hopkins, Sc Usa
Post Number: 166
i have a fosgate amp that came with a nob that adjusts my bass. the guy who installed my system said that this nob controlls my gains and when it is hooked in it eliminates the purpose of the gain nob on the amp. is this correct. i dont want to mess up my gains.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5998
gain and remote bass boost are totally different things.
disconnect the remote knob.
set amp gain the way it should be.
then connect the remote control and use that to vary the amount of bass per song/CD.
