1 big sub or severl smaller ones?
Username: Rob_brown
Post Number: 28
could anyone tell me if i would reach higher spl levels in an suv with 1 15" brahma or several smaller but less expensive ones.. if so please suggest a few models. keep in mind i would like to maintain decent sq and i don't know if that is attainable with any less expensive subs. thanks for your help
Username: Zacdavis~
Post Number: 258
well, it depends on how loud you want to be, i have an explorer and my streat beat system consists of just one ten and it does 141 on the new termlab mic(sensor). for me one 15 would be loud enough but i'm not sure how loud you want to be. and those brahma subs can kick alot of azz, i'd say one is plenty if your not planning on winning competitions with it. lets put it this way, i bet you could do mid to upper 140's with that one sub in your truck with the right set up, i dont even know if i'm even answering your question, its gettin late n i'm tired
Username: 54danny54
Post Number: 48
id say go with 4 or 5 10's
