Amp question
Username: Jarryd2018
Post Number: 64
wat would be a good amp to power to 10" vmax subs if they are both rated at 200watts rms by 4 ohms
i dont want to spend much money cuz im kinda broke right now but im gettin the subs for christmas
Username: Carguy
Post Number: 396
Hey Jarryd, try the eBay for used amps. One cheap in price that come to mind is MTX 6500D. It's rated 500W rms at 2ohms and 775W at 14.4v.
Last I checked it was going for $70.
Post Number: 65
how well would that power those 2 subs all together they have 400 watts rms at 4 ohms so thats wat i need to get
Username: Carguy
Post Number: 404
No Jarryd, if you send 400W to your subs, it'll blow. The subs can only handle 200W. The amp I mentioned will more than max your subs and have plenty of power left. Remember it is 500W at 2ohms.
One more thing, you can have 4 200W subs and it's still 200W max.
Post Number: 66
they are 200 watts apiece so i need 400 watts to power them
Username: Carguy
Post Number: 428
Hey Jarryd I don't think you understood me. Your 200W subs are 200 apiece. You can hook them in parallel or series and it's still 200W. If you supply 400W to them, they will blow, trust me.
