One 10W7 two 10W6v2 or something else?
Username: 69vee
I would like to know if I would be better going with 1 10"W7 or 2 10"W6v2. If you guys have a better suggestion other than JL Audio, let me know. I have a 03 Yukon XL. My interior set up is front captain chairs, second row captain chairs, and a third row bench. I do not want to loose any cargo space, so instead of putting the sub box in the back, I would like to place it between the second row captain chairs. I would like to go with a sealed box with the speakers firing down or forward(depending on using 1 or 2 subs). I have about 11.5" in clearance between the chairs. That means the JL audio recommended demesions will fit just fine for the w7. Again, I am not opposed to other subs. I want really clean sound. I am choosing a 10 " because I listen to rap, jazz, and rock. Thanks for any input.
Username: Glasswolf
Post Number: 919
elemental designs (www.edesignaudio.com) A series is another option.
I'd consider a single 12W7 or 13W7 with the volume of that cabin though.
big vehicle.
want to move more air.
Username: 69vee
Couldn't I use two maybe three 10" subs to move more air or do I have to go with a 12"? I am not against having a 12", I just don't have room for one in between my captains chair. Also, do to my music tastes, I have been geared towards a 10". Money is not the issue. I want to do it right. If I have to wait 4-8 months to save the money I will. Thanks
Username: Its_bacon12
Post Number: 74
check out infinity kappa perf 10 dvq, its a great sub, or the 10 inch brahma, IDMAX10, but a 12w7 will do you great with a 500/1 amp from jl audio...those r just suggestions...also RE triple x 10"
Post Number: 75
a 12 will save you plenty of space verses going with 2 or 3 10 inch subs btw
Username: 69vee
I only have 11.5" between my captains chairs. I won't be able to fit a 12" sub. I do have enough room for 2 10" subs, or 1 10W7. If you can configure me a box for 12's that will fit betwwen 11.5", I am all about it.
Post Number: 83
lol um well...i would go with the 10w7 or a 10inch brahma or idmax10....those r ur best bets
Username: Hydro
Post Number: 76
The 10W6v2's are very nice for SPL and Sound Quality and would have more Air Displacement then one 10W7 does.
Post Number: 86
yeah ur right....if only u had more room to get a 12w7 or 13w7....oh well, yeah i would get the two 10w6v2's if your leaning toward JL audio and towards more air movement, well best of luck with your stuff man :-)
