MTX Thunder 9500 VS. JL audio w7
Username: Araknid
Post Number: 22
what do u think check out mtx .com and look the thunder 9500 they compare it to the W7, u have to go to the bottom of the page it says thunder9500 vs JLW7
Username: Deathshadow
Post Number: 283
The thunder will get raped by JLW7s, Adire Brahmas, X.X.X, Alpine Type Xs, etc... It's crap!
Username: Thehammer
Mount Holly, Nj US
Post Number: 10
no cause i have a 13.5 w7 with a 1000/1 and i have the 15inch 2ohm 9500 and it crapped on the W7 wit no problem
Username: Hdubb
Farmington, Nm Usa
Post Number: 59
same box and same music? same amp settings, same environment, everything the same, except for the sub?
Username: Kenwa
Post Number: 57
On the MTX website they compare a 10 inch W7 to a 10 inch 9500. when you get to 12s the JL is better than the MTX. And compareing a 15 inch sub to a 13.5 inch sub is like comparing a 10 and a 12, but i bet the JL is still louder. And damien you where on a roll until i saw the alpine type X in there, it should not be classified with the other subs you listed, yes its a very nice sub but not half as loud, and MTX isnt crap just not the best.
