PLEASE answer my ?
Username: Araknid
Post Number: 9
what happens if the ground wire comes in contact with the channel + ???????????
i think the car was on if that matters
Username: Jdc
Post Number: 18
is that for the amp or the head unit
Username: Araknid
Post Number: 10
the ground wire of the amp touched the channel 1 + on the amp, while the everthing was connect
Username: Jdc
Post Number: 19
it may have fried the amp. dose the amp still work
Username: Araknid
Post Number: 15
when ever i hook it up the speakers emit wierd constant beat like sound, but what i think i did was fry the the signals coming from the head unit
Username: Jdc
Post Number: 20
i would go get the amp tested and see what the store says to do. does the amp still have a warnity
Username: Araknid
Post Number: 17
i think its the head becouse i hooked up another amp and it did the same thing
Username: Jdc
Post Number: 22
if you have a different head unit around try to switch them and see if it still makes the noise
Username: Araknid
Post Number: 19
ok i have one ill try thanks man
