Box?
Eddie
What size box should i get for 2 Adire tempest 15's ? I don't have too much room. Also sealed box or vented or what? And where to buy one at?
Help2
Sealed boxes are smaller, but give less output
compared to ported boxes.
Im sure you wont need much more output anyhow.
If I were you, Id build my own box...so that
you could get it to fit better than a prefab box.
Boxes are really to make, and cheaper too.
If youre nervous about making one...
I could design one for you if you gave me the
max dimensions of your car.
But if your set on buying one..
Look for a company who uses at least 3/4" MDF...
The box shouldnt cost much less that 150 bucks
most likely
Username: Mr_kebo
Albertville, Al USA
Post Number: 19
Help2 think you could help me on a box design for 2 12" SPL subs. Goin with ported, the cather is that its goin in a single cab truck. Plenty of people have told me that it can be done but no one is willing to help me. Each chamber needs to be 1.75cu ft. Email me at Kebo18@gmail.com if you can help
Eddie
about what would be large enough demention for 2 15's?
Help2
Just give the the largest possible dimensions that will fit in your car....
the width between the wheel wells, the height without hitting the lid supports, and the depth.
