Anonymous | I want loud deep sounding bass...I have no preferences for brand or anything...I just want good results...Just give me your opinons. |
Bronze Member Username: Crazy3rdgenLong Neck, Delaware U.s Post Number: 44 Registered: Sep-04 | U kno their gunna ask you your budget on money and what amp u have if you dont.. ur budget for that also |
Bronze Member Username: Crazy3rdgenLong Neck, Delaware U.s Post Number: 45 Registered: Sep-04 | and how much space you have/what-car/truck |
Anonymous | No budget limit as of now and amp: two a2300hct(2400x1) |
Anonymous | have a navigator |
Bronze Member Username: Crazy3rdgenLong Neck, Delaware U.s Post Number: 46 Registered: Sep-04 | damn hm.. how much space u have to work with? |
Anonymous | the cargo area (not willing to modify the truck) -sub box needs to be moveable amps will go under seats |
Anonymous | 40in by 30in |
Anonymous | maybe bigger |
Anonymous | will be back in a bit, keep replying, i'll respond soon enough |
eric77 Unregistered guest | So moneys not an object... In that case I'd say 3 jl 12w7's each powered by a jl1000/1 in a custom fiberglass box. My friend has this exact setup and I cant imagine a system that sounds better than this. It is unbelievable. I tihnk his system cost him about $4-5k. |
Anonymous | i kno they sound good, (cuz i have JL now) but i heard i could get the same quality without the price tag |
Anonymous | he has a nice setup, that setup was my original idea, but it takes a little too much space. still need space for other things |
Silver Member Username: JohnnylemoineLaPlace, Louisiana United States Post Number: 275 Registered: Aug-04 | Ok, first listen to Lil Scrappy no problem, then get a L7 15 and build a 8.5 cuft. slot ported box for it. This will gaurantee LOW BASS. O yeah, get a POWER 501bd to push it at 2ohms. Now listen to Lil Scrappy again with your new sub. |
Bronze Member Username: KenwaPost Number: 38 Registered: May-04 | Your way off on this one Johnny, kickers arent going to be all that loud. Look at adire audio brahma, RE X.XX, image dynamics ID Max, and eclipse Ti series, there are prolly some im fogetting but this will give you a start. |
Eric77 Unregistered guest | The subs kenny listed sound pretty good. I myself am somewhat fond of diamond audio. That being said, I think you should look into getting 3 12" tdx woofers. They would run you about 400-500 apiece. Then I would get 2 elemental designs nine.1s. This amp is $315 shipped and will put out close to 1500w even though it is only rated at 1200w. Also, this amp is stackable meaning you can combine two to double the power output and connect them to three subs. If you really need the room then i guess you should run it sealed to save space. If I were you Id make a boxsimilar to this. But obviously with three subs. http://img.photobucket.com/albums/v190/eric77/Image_50.jpg It shouldnt take up too much space and should sound great. BTW, in that picture you would really only need the actual box. Just ignore the amp in that enclosure. You could find somewhere else to mount your amps to save space. I hope this helps. Eric |
JuNGLiST Unregistered guest | How about an Inhuman 18? |
Silver Member Username: DecdeCanada Post Number: 243 Registered: Sep-04 | If u have that much space, the 18'' would be quite nice. If you check the 18'' stroker, you will be breaking more than your ears, that i can garanty |
