Amp and wiring for a pair of infinity perfect 10.1d's
bob dole
I want to buy 2 infinty kappa perfect 10.1d subs. They run dual 4 ohms. I want to put the subs in seperate boxes. my question is should i run them in parallel or series, and what kind of amp should i get? like mono or 2 channel, and how many watts??? thanx
Username: Its_bacon12
Post Number: 161
hmmm those run at 300 or 350w rms i believe...
buy a JBL BP600.1 amplifier, about $210 but run the voice coils in paralell and the subs together in paralell and you'll end up with a 1 oihm load and that amp puts out 600w rms at 1 ohm, its practically a perfect matchup
Username: Glasswolf
Post Number: 1301
you may want to get teh single coil 4 Ohm versions for two subs
that'll make a 2 Ohm load in parallel on a JBL BP600.1 or Kicker KX600.1 amp
300W each
Username: Shouder
Post Number: 8
Another thing you could do is just run the voice coils in parallel to 2 ohm load. then get a 2 channel amp and run each sub to a channel at 2 ohms. This way you don't have to worry about over powering them.
