Subs cut in and out ohm prob?
Username: Lonewolf2683
Post Number: 7
Well ok i made a post a while back and i finally got my speakers running. Turns out my 1000w amp had a burnt resistor and i dunno whether it'd be cheaper to repair it or buy a new one.
But the real problem is i have my old kenwood 600w 2ch amp and i have the 2subs bridged in parallel which i believe would read as 2ohms to the amp (correct me if im wrong) after a while the subs cut in and out. I turn the car off go back and check the amp and wow...could fry some eggs on there easily. Since this amp is 2 channel i feel its weak to run bridged subs cause of the ohms it detects but would it be better if i wired the subs in series or would it just make matters worse and lower output.
Any advice would be highly appreciated. Thx in advance.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 97
Put each sub on its own channel.
