Pioneer DEH-2300
Username: Kellygirl01
Post Number: 8
I suddenly lost power on the remote amp lead on my Pioneer DEH-2300 after testing for voltage to connect to power amp.
Is there any to fix this? The radio works fine besides that.
Have you checked the fuse on the back of the receiver. It's in the back behind the electrial plug in. 10Amp. When you unplug the wiring at the receiver you will see it pluged into the back. Do you have the wiring diagram for your DEH 2300. I need one bad.
