NEED HELP!!!
Username: Counterstrike
Post Number: 14
what kind of amp would i need if i bought 4 Alpine SWR-1521D 15" Dual 2-ohm Voice Coil Component Subwoofer?? thanks for all the help
Username: Stumped
wire them parallel to make the output a 2 ohm load.
so look for an amp that pumps 1200-2000 watts @ 2ohms since the subs are 200-500 watts rms
Post Number: 15
what brands do you recommend?
Post Number: 16
and what type of amp 2 channel, mono, multi ??
Username: Carguy
Post Number: 348
Hey Counterstrike, for subs, class D mono will work just fine. The brands you can look at are Rockford/Kicker/JL/Audiobahn 4125HCT or 2300HCT/MTX/MA Audio.
Always look for sub amps with remote bass control. You won't regret it!
Username: Stumped
Post Number: 9
i would automatically think a 2 channel amp..but i hear its better output power wise to go with a mono amp.
i would go with jl audio,kicker,hifonics
