Brahma and X.x.x.
is there any difference between thw Brahma and the X.X.X.? they both have the xbl^2 tech. so is there any difference
ThatGuyYouKnow
Xmax, I think is the diff, but iv heard there sister companys.
which is better or are they that close to the same that it doesnt matter? I also noticed that the brahm has a triple stack motor and the X.x.x has a double stack, but i think the re has bigger magnets
Username: Hdubb
Farmington, Nm Usa
Post Number: 55
i just learned that Resonant Enginnering and Adire Audio are NOT related. they just use the same xbl^2 motor tech. thats kind of seeming that the X.xx and the brahma look almost exactly the same.
