Quality Brands of multichannel amps?
Henry C
Which brands and models of multi-channel amplifiers between 50Wx4 RMS and 100Wx4 RMS at 4 ohms could you recommend me? I want to power two pairs of Infinity Kappa Perfect 6.1
I would prefer quality than power. Thank you.
NappyDugout
JL Stealth 300/4 MSRP $429.00 is the way to go.
You'll be extremely happy with the results. This is show quality, built like a tank, and literally five times the technology of amps 1/2 the price. Check out acaraudio.com
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 98
MTX 564
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 99
Buy on ebay if you can. Cheaper. Check reviews on seller before you buy.
Henry C
NappyDugout: I couldn't find the exact model you told me (JL Stealth 300/4). I found a JL Audio 300/4 Slash Series that is 75W x 4. Is that the one you were telling me??
Lucas Beckner: Have you tried MTX? I haven't read good news from MTX in this forum, is it really good?
I appreciate your responses... =)
NappyDugout
Bullseye. Buy it and go on the jlaudio site, I think it's jlaudio.com to see the specs...dude the technology in this thing is amazing.
JL= they use these in the shows. Nuff said.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 107
I use a 1501D for my subs and a 564 for my doors. They work great. Clean and powerful.
