Fuse problem
Username: Martscorsa
ManchesterEngland
Post Number: 7
the wire that goes from my amp to the car battery has a fuse on it and keeps blowin from time to time my amps a mrp-m350 alpine is there anything i can do apart from buyin a shed load of fuses??
Username: Carguy
Post Number: 315
Yea you can buy a proper sized fuse. Take your amp's rms power rating divided by 12v and it'll give you the fuse's approximate size.
Normally the fuse is 60A but if you're sure that there's nothing wrong with the amp/wire shorts then go one higher like 70A.
ManchesterEngland
Post Number: 8
i dont understand ive got 2 yellow fuses in the amp they are 20amp and the one thats near ma battery is 30 am if thats any help thank isaac
Username: Carguy
Post Number: 318
Hey Martyn, there's your problem. Two yellow fuses add up to 40A. And you said your main fuse is 30A. Put in 40A and it shouldn't blow.
ManchesterEngland
Post Number: 9
so the fuses in the amp have got to be smalled than the one thats near ma battery? if so thanks isaaac u a star. :-)
Username: Carguy
Post Number: 319
Very close, the fuse near the battery has to be greater than or equal to the total fuses in the amp.
ManchesterEngland
Post Number: 10
theres a word for people like you isaac helpfull lol cheers pal
