Archive through November 19, 2004
Closed: New threads not accepted on this page
  Thread Last Poster Posts Last Post
Something went wrong after amp installAnonymous1
Amp for 4 10" subsJordan Athnos5
Would This Amp WorkTheNewbie5
Jeep GCH'99 amp installationotabek rasulov11
Need InputBadAzzBowtie5
How many amps dose a Generator put out?BadAzzBowtie4
How to hook up two ampsjustin volker4
4 speakers to a 2 channel amp?....Ray G2
Does anyboby have an opinion on 5 channel amps?press12
Y does everyone ignore my posts? WTFJustin6
What does MOSFET meanJonathan10
Amp keeps blowing fusesDman7_94
Hookin up my ampPimped_Escort16
Good Amptaylor172
Need wiring/amp help alex4
Stuck on what amp to get...glass, john, anyone?marshall white1
What amp should i get?Trigger Happy4
Need amp helpTrigger Happy1
Help with amp problemsBrian Olesen1
What is the difference between Digital Amps and Others?Eric Hughes4
Need Help With Picking An AmpGlassWolf5
How are "cheater" amps rated in comps???GlassWolf2
GlassWolf Or any one else with input. GlassWolf5
Amp question for 50's car for the allmighty GlasswolfGlassWolf2
Suggestion on AMPPeter Ljubanovich1
Are Coustic Amps any good? (ie - good value, not the worlds best am...Anonymous15
Good system for $700Damien Roberts11
Whats a good amp for ...Jon26821
Amp kiteric773
Need opinions. Mcintosh or New Tube amp?Eric Hughes5
-Low end amp noise's, from head unitJosh Smith4
Square port or circlederek moffett8
Adding another amp need helpIsaac6
Car audio amatuer seekin assistenceGlassWolf8
Help please =)GlassWolf5
HPF, LPF, All Pass, which one is better?GlassWolf3
What do i set my XO at?Daniel1
Pioneer ts-wx20lpaBrad0042
How to run 4 speakers and 1 sub to 500w amp.trevore1013
Kicker kx300.2gabe vicara1
Crossover on ampdbomb3
HELP!!!! Is this cadence amp any good????? glass, john, baconAnonymous5
How is this for a starter set upGlassWolf6
Kicker XS 100marshall white7
Which battery would supply more powertafkam4
2ohm + 2ohm ??jonathan dickson3
Amp for tempestsghghghjkj1
Good 600w x 2 amp?Jordan Athnos3
Infinity or audiobahn or another amp?m B18
Apline Type X /Ampmartyn9
Remoting 2 ampsDamien Roberts4
? enough power or notDamien Roberts2
Bought amp, need help wiring details...San Bas1
Whats a good 4 channel amp? San Bas6
Rockford Fosgate Power 750s ?Fosgate Monster Audi7
How big of an amp do i need????Fosgate Monster Audi2
Is a 2003 (not the new one) Rockford Fosgate 1001bd 1 ohm stable am...Fosgate Monster Audi2
How do i hook up two ampsSteve S.2
S/N Ratio: Deciding Factor?GlassWolf7
Extra powerAnonymous10
Amp gain needs to be set to max despite 4 volt preampGlassWolf23
Bridging an amp GlassWolf3
Need info on Eclipse amp 3021GlassWolf2
Ohm speaker and amp questionHunter Warren2
AmpSucubus2
What would be a perfect amp for one 10" Brahma in a sealed box?Alex Kintis4
Jl Audio or Rockford Fosgate?big don4
Bridge amp to power front and back speakersIsaac2
What Kind Of Amp Do I NeedIsaac2
Amp as Paralell??? bridge???Isaac2
How much of an amp can a 70amp alt handleIsaac2
Simple amp questionmarshall white3
Adire Shiva...Push it with what???marshall white4
What amp to use with 2 audiobahn immortals?jon doe2
Kicker or memphis amp for shiva steve7
Need 4 channel amp that can be bridged to two ohm mono!Isaac5
2 jl w7's ...what amp??Joseph2
What amps do i get??2x1100rms subs,+ 4 100 watt speakersGlassWolf18
Lights Flicker after installing a capacitorGlassWolf2
Amp Wiring?Justin1
What 4 12" subs and amplifer for under $600Anonymous1
Amp for aw1251t audiobahns subsgabe vicara3
Jbl 1200.1 Isaac8
SPL Z1X-2400DSucubus2
1300 watts??Isaac2
Kicker kx1200.1???GlassWolf3
What kind of amp is best for me?GlassWolf6
Need Help With Picking Out A AmpGlassWolf2
Help needed on amp and sub set up!!!lucas beckner2
4ga wirelucas beckner7
Old Hifonics ISIS questionMoorey4
Old Hifonics ISIS questionpress13
BLITZ amps????????xxmdfmkxx6
Amp to run 4 CVR 12sGlassWolf3
Distribution block?GlassWolf2
What is a subsonic filter????????GlassWolf3
Hooking up Amp to stock deck.Daniel Wright3
How do you install an Amp?shawn Corp3
Suggested amp for 350w pioneer pair?Ernesto Alvarez5
Amp for 1 kicker s12L5.lvloises3053
