Audiobahn
Username: Mxpxl82
Im looking at the audiobahn ABF model for my car, bad idea?! Ive read in earlier posts that basically everyone dislikes audiobahn speakers. These are supposed to be like their top of the line speakers so I was wondering if you guys could tell me what you think of them.
audiobahn ABF39T 6x9" 3-way kevlar
Chrome Plated Basket
Glass Fiber Composite Cone
EPDM Rubber Surround
Removable Remote-mount Tweeter
2 Layer High-temp ASV Voice Coil
4 Ohm Impedance
Complete With Mounting Hardware
Magnet Weight: 40 oz
Power Handling: 215 RMS
Frequency Response: 20Hz - 21kHz
Sensitivity: 96dB
Impedance: 4 Ohms
Mounting Depth: 3 3/4"
audiobahn ABF46T 2-way kevlar
Removable Remote-mount Tweeter on all 2-way Speakers
4 Ohm Impedance
Magnet Weight: 20 oz
Power Handling: 80 RMS
Frequency Response: 50Hz - 21kHz
Sensitivity: 94dB
Impedance: 4 Ohms
Mounting Depth: 2"
No/Yes/many....?!
The rms on the 4x6's is 80 and the 6x9's are 215. I want to get an amp but Im not sure if my head unit pioner 7600 (50x4 watts) will be enough power to power the front speakers by itself and then just get a 2 channel amp to power the back speakers.
If these speakers arent good can you throw out some speaker brands/model types.
Thanks....
NappyDugout
This is like buying the most expensive house in the ghetto. If you like Kevlar, go Focal. Personally, I'm a polypropelene boy.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5861
my best suggestion is to audition a pair yourself.
component speakers are very subjective. everybody has their own taste for what they like, and most companies have a unique sound to their speakers without heavy signal processing to correct for colorations.
see what sounds good to your ears.
I like rainbow reference and dynaudio myself, given the choice. everyone has their favorites.
