Camaro Monsoon Speakers
CLS87
I have a 2002 Camaro with the monsoon system and one or more of the stock speakers have started to make an annoying buzzing noise and not playing any music. I am going to replace all of my stock speakers with better ones. What would the best speakers (within a reasonable price range) to replace these speakers:
Front Speakers
6.5" inch "S" oversized (6.75"), 2 ohm, located in the lower portion of the doors.
.6" 4 ohm tweeters located on the same axis as the 6 1/2 inch. Kinda like a coaxial speaker.
Sail Panel Woofers (Rear seat)
6.5" 2 ohm subwoofers located next to the rear seats
Rear Speakers (under hatch)
4" 4 ohm midrange speakers located in the rear hatch panels
NappyDugout
Dude, read the other threads below. There are about 7-8 threads in the past two weeks dealing with door speakers. Annoying buzzing noise? Make sure they replace the wiring with some high grade stuff too. Stock wire is the worst.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5876
that buzzing could be a bad amp channel as well
