Better subs to buy
Username: Imstillhere
Michigan
Post Number: 21
ok i was either thinking the Audiobahn 10" Subwoofer (AW1006T) = this thing has 900 watts RMS power and auminum cone or do u think the Audiobahn 12" Subwoofer (AW1206T)
it has 1100 watts rms power look at them both here ..............................................http://www.circuitcity.com/ssm/Audiobahn-12--Subwoofer--AW1206T-/sem/rpsm/oid/77 180/rpem/ccd/productDetail.do OR
http://www.circuitcity.com/ssm/Audiobahn-10--Subwoofer--AW1006T-/sem/rpsm/oid/77 175/rpem/ccd/productDetail.do
THANKS FOR UR INPUT
Sucubus
Dont buy Audiobahn.
Please.
Its chromed out crap...
I think the saying goes...
you can't make a turd shine.
Look at that surround..honestly
It makes a 12" cone look like an 8"
Its probably got an xmag of like 6mm tops.
They dont list that of course.
If youre going to spend 300 hard earned dollars.
do a little more research.
Youll thank me later.
Michigan
Post Number: 22
what do u think of these
http://www.bestbuy.com/site/olspage.jsp?id=1069302879391&skuId=6252486&productCa tegoryId=cat03081&type=product
Michigan
Post Number: 23
or what do any of u recomend
i wnat the HARDEST HITTING bass in the whole neiborhood
Username: Jmloughrey
Farmington, CT
Post Number: 402
..give me a budget and it can happen
Michigan
Post Number: 24
a budget is 900
Michigan
Post Number: 25
that is only subs and box
Farmington, CT
Post Number: 404
well what are you looking for, SQ or SPL?
Kenny H
what kind of amp are you using and watts the wattage on it?
Michigan
Post Number: 26
its a alphssonic .....1000 watt or 2000 bridged im looking for hard hitting bass ....like that could bloww all the windows out of my car
Username: Chevy_for_life
Post Number: 212
get some RE X.X.X.
Username: Solacedagony
New Jersey US
Post Number: 32
Or RE MT if you really want SPL.
Michigan
Post Number: 27
where can i look at these
Michigan
Post Number: 28
where would be a good place to buy these from
Farmington, CT
Post Number: 422
www.reaudio.com you'll have to order the XX.X or MT directly from resonant engineering...email them for the number you'd have to call, i like glasswolf or jon has them on hand somewhere...somebody else might too
