Bronze Member Username: BusinessboyPost Number: 52 Registered: Sep-04 | been told the reason why i am having problems with my kicker kx850.2 and my 15" L7 is because the sub cant be bridged that correct????? |
Bronze Member Username: SolacedagonyNew Jersey US Post Number: 53 Registered: Oct-04 | Assuming your sub is 2 ohm DVC, you can wire it two different ways. That is a stereo amp, so you can wire it in stereo (1 channel to each voice coil) or wire the coils in series to the amp, which would be a 4 ohm bridge. Kicker amp info: http://www.kicker.com/ShowPage.cfm?filename=04kxstereo.html&menu=KXAMPS |
Bronze Member Username: SolacedagonyNew Jersey US Post Number: 54 Registered: Oct-04 | And also, you bridge the amp not the sub ;) |
