Infinity Kappa Perfect 6.1 fits in 2004 Accord???
Ivan K
Anyone knows if the Infinity KAPPA Perfect 6.1 component speakers fit in front doors of a 2004 Honda Accord Sedan?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5781
with some modification, yes.
the plastic dish behind the factory speakers needs to be removed, or cut away using a dremel or air nibbler.
