I need louder subs, any suggestions?
Kenny H
Currently i have 2 kicker 10 inch L7 subs with a memphis MC1000D amp. I am very pleased with the amp but the subs just arent loud enough. So basically what i am asking for is the loudest sub setup with my current amp, its pushes 1100 watts at 1 OHM. The subs will be in a 95 camaro so there isnt a whole lot of room to work with. I can spend up to $1000 but the cheaper the better just as long as its LOUD.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5646
two adire brahma 12" subs
that'd do the trick. use 2 ohm subs. that'd get ya about 550 wats each
they should hit very hard in a decent box
Kenny H
Yeah i have heard good things about those subs but where can i buy them? Also how do the brahmas compare to image dynamics IDMAX subs, Power Acoustic MOFO, and Pioneer premier 2000SPL?
Help2
Brahmas and IDmax are comparable.
Power Acoustic is crap.
Pioneer Premier is an OK sub,
but go with Adire or IDmax.
Id say the IDmax, but thats me.
Also look into RE Triple X if youre considering
the Brahma.
Kenny H
Between the IDmax and the brahma which will be louder, i plan on 2 12s, and will both of those subs run on 550 watts each?
Help2
IMO....The IDMaxs.
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1058
the idmax's handle 1000w rms but throw em in a slot ported to 26-29 Hz and they wont need more than 500-800w rms to get moving and sounding awesome
i would go with idmax's too btw
Kenny H
Ok that sounds good, where is a good place to buy them?
Username: Elecgenius
La Puente, Ca United States
Post Number: 121
hey kenny , i dunno if this will help u any, no one in the forums i would go to was able to give me a link fo this. i had to work it on my onw. anyway http://www.subthump.com/acamaro.htm
this site has stelth boxe,, even boxes for 2 15's specifically made for camaros and f-birds. i would recommend 1 15 in a 3.4 cu.ft box.
Kenny H
I have a specially built camaro box right now and when i get new subs there is a local shop that i am going to get another one from, thanks for your help though.
Username: Deathshadow
Post Number: 210
rofl @ Power Acoustik
Username: 54danny54
my suggestion is stay with the same brand but 15's and a better amp
Username: Glasswolf
Post Number: 5703
www.adireaudio.com for the brahmas.
Username: 54danny54
Post Number: 32
Try 2 FU-15's from planet audio
Username: Glasswolf
Post Number: 5769
planet audio, aka BOSS audio.
be wary of anything with a name like "FU" or "FUBR" or "MOFO" or "SUKDIK"
