What subs to go with??
Username: C12698
Oklahoma
Should I go with 2 alpine 1241d's or 1221d"s?? I am kinda new to stereo systems and was curious if there was a sound (bass) difference.
Also depending on which one of those pair I go with, should I go with 2 kenwood kac-929 amps, one amp for each sub (bridged), or 1 rockford fosgate 1051s to push them both??? I already have these three amps is why I'm curious.
Username: Avalanche
What kind of music do you listen t and what kind of box are you going to put the subs in. Take into consideration that alittle bit of everything plays into making a decision.
Username: C12698
Oklahoma
I am using an enclosed box and I mainly listen to hip-hop when I'm trying to rock my car.
Help2
power is power man.
For the sake of your electrical system Id get the
dual 4s and a Class D amp...
JBL BP600.1 or something similar.
Plus the Rockford is a little overkill for those subs, but it wiil work.
Username: 54danny54
Post Number: 35
get a few 12 inch subs from kicker...that will do ya
