Quick question
Username: Ha_split_lf
Post Number: 22
will a crack in the mounting hole of my sub enclosure make any difference in power or sound? also could it potentially cause damage to the sub?
Username: Bdb_86
Bemidji, MN Usa
Post Number: 202
if its a crack that goes all the way through the box and doesnt get covered in a way that it would be sealed then air can leak and you may get poor sound and it could damage the sub
Post Number: 23
In that case should i get a new box?
Username: Jdc
Post Number: 7
yeah you should
