Help me find right subs
Username: Link1235jeffvw
Usa
i whent to bestbuy today and bought a Sony 1200W Bridgeable 2-Channel MOSFET Amplifier with Variable Low-Pass Crossover Pump up the power flow to your car speakers and intensify the cruising experience with this 2-channel amp. The variable crossover lets you find the right range for your speakers or subwoofer.
1200W peak, 500W RMS x 1 @ 4 ohms, bridged
MOSFET (Metal Oxide Semiconductor Field Effect Transistor) power supply and output devices for clean, steady power
Variable low-pass crossover (50-300Hz, 12dB/octave) for use in subwoofer applications
200 watts RMS x 2 @ 4 ohms
250 watts RMS x 2 @ 2 ohms
Product Details
Warranty Terms - Parts 1 year
Warranty Terms - Labour 1 year
Product Height 2-1/4"
Product Width 15-3/4"
Product Weight 9-1/2 lbs.
Product Length 10-7/8"
Continuous Watts per Channel (4 Ohms) 200
Continuous Watts per Channel (2 Ohms) 250
Continuous Watts Bridged 500
Number of Channels 2
Crossover Variable 50-300Hz low-pass filter
Amplifier Class and Type Class AB
Tri-Mode Yes
Low-Pass Filter Variable (50-300Hz)
Speaker-Level Input Yes
Crossover Frequency Range 50-300Hz
Bass Boost 0-10dB at 40Hz
k
what subs do u guys think i should get for that amp thanks
please help
Usa
help please i wont 2 subs
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 51
can u take that amp back and get a class D? Thats what I would do. How much money to spend on subs and how big do you want em?
Username: Kenwa
Post Number: 30
start by taking that amp back, sony is junk. Good amps include memphis, kicker, MTX, and JL audio among others.
Usa
thanks but what subs 8 to 12 inch subs please help i go the amp for 188 please help
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 54
The size of the sub is up to you and your taste of music and your price range.
Usa
i wont a strong really really loud bass looking 100 and less
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 55
get a couple of kicker comps. Really good for the money. goto kicker.com to check them out.
