Looking for a pair of 5x7/6x8 speakers
Username: Xxkmfdmxx
Post Number: 21
Which speakers would you reccomend for under $80(I'm buying them on eBay) They could be either 5x7s or 6x8s
Also any reviews on the Pioneer TS-A6870R? I listened to these in a local audio store and they sounded quite well for $55
Username: Cruxis
PA USA
Post Number: 22
I have four of them. They work pretty well. However, for that amount of money, perhaps you should try for infinity speakers.
Username: Xxkmfdmxx
Post Number: 22
Which Infinitys would you reccomend? I heard the 6802CF's are good, is this true?
Username: Xxkmfdmxx
Post Number: 23
Also what about Alpines SPS570A?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5245
Infinity Kappa 4x6 plates.
those are about the best you'll find in that crappy speaker size.
Username: Tullphan
I just got a 98 Crown Vic. My options for the front door are either 5 1/4", 5 1/4" components, or 5x7/6x8.
What kind of mods are needed for a 4x6 plate to go in there?
Thanks.
Help2
Go with the comps man...better sound quality
and imaging.
only thing worse than 4x6 are 4x10s :-)
Honestly...what were they thinking making
4x10's...
