Kickers
Username: Johnts
how long do you have to breakin the 12inch l7s and whats the best way i have a 3000wat poweracoustik on two 12inch l7s
Username: Solacedagony
New Jersey US
Post Number: 39
I remember someone saying 20 hrs with your volume only up to 20 to 40%. Also, make sure your gain is set correctly. If you don't know what that means, you should probably take it to a shop to get setup.
