Remote start/ car starting problem
Username: Mykegee23
Edinburg, TX U.S.A.
in the mornings, i try to start my car with the remote start and it doesn't turn on. It does crank but it won't start. Once the engine has warmed up and then I use the remote start, it works. What can i do to fix this problem?
qwerty
try having a Wank before you use the remote start, it always works for me!
