GlassWolf
Username: Therainman
Post Number: 14
Im going for overall sound quality.Out the the Treo series and Image Dynamic Series which would be best for my s10 91 ext cab.
Also could you tell me a good box that would suit that woofer.
whats the gain or benefit if any by gettin a 4 ohm version of a woofer rather to the two ohm version?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5641
the load will totally depend on the amps you choose, and how many subs you use.
no difference in sound either way.
I'd strongly suggest you audition the treo and ID subs to see which you like.
both are very good subs.. its mostly subjective at that point.
for a box, in an S10 go sealed.
Post Number: 15
so any specific model numbers of the two?
what im asking is not just the brand but the series and the class along with the model number like the IDMAX12 v3 ppl say its a very good woofer. is that there top sound quality woofer? if so which of teh treo woofers does it compare or in the same class as.
Post Number: 16
