Like
IDmax
Username: Hbguy
Anyone out there have any opions on the IDmax12v3 sub? I have an amp that will provide plenty of power. Looking for a hard hiting everyday sub
Help
Its a great SQL sub.
Ive never owned one, but Ive heard great things.
Perhaps a little much for an everyday driver IMO.
but Im old.
Username: Hbguy
Thanks for the response. I was looking at the Kicker 12 L7's then i found this idmax for about the same price. The L7's have some bad points such as stress an distortion, so I hear. The W7's are so expensive, and the W6 only holds 400 watts RMS. I am new to the car audio world. Do you know of any subs in the $300 price range that perform well? My amp will put out 1100 RMS @ 2 ohms and 2000 watts RMS @ .5 ohm.
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1054
Resonant engineering triple X
adire audio brahma
IDMAX
digital designs 2500-9900 series
diamond audio TDX
there are many super subs out there in the $300 range that will vastly outperform L7's and compared to a w7, much better buy
Username: Hbguy
Thanks for the info, this is exactly what I was looking for.
Kenny H
Where can you buy the subs listed above? I found the IDMAX on sounddomain.com but besides that i havent found the others
Username: Hbguy
Check out www.onlinecarstereo.com for Diamond Audios line.
www.adireaudio.com for the Brahma
www.REaudio.com for Resonate engineering
Facebook
Shop Related Deals
Directory
