Mono amps??
jameshiller
Could someone just tell me wheather you can connect more than 1 sub to a mono amp? If so how many thanks!
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5570
yes you can, and as many as you want as long as they each get proper power, and they are wired in series or parallel to match the load properly.
usually anywhere from one to four subs are wired to a single mono amplifier.
If you go with more than 4 subs, or need additional power, consider separate smaller amps.
james111
thankyou, do you happen to know how many speaker connection terminals it has, its 2 isnt it?? charz xx
Username: Glasswolf
Post Number: 5576
many mono amps have two sets of speaker outputs yes.
they're just parallel terminals to make things easier to wire.. they go to the same pair of amp output lines internally.
