Best Choice?
Username: Rds11
Louisville, Kentucky
Post Number: 9
Okay I have a 1994 Acura Integra LS, its technically called a 3-door hatchback the trunk being the third door. I was looking for one 10" or 12" that would would give me great SQ and for the times when called 4 it would put out some good SPL. I listen to my music at moderate to high volumes and it would need to stand up to daily driving. I few I have considered strongly is the Orion H2, Adire Brahma, Alpine Type-X, RE x x x, and the Eclipse Titanium. also if u recommend a sub would u also recommend a ported or sealed box?
I listen to mostly rap if that helps. And I don't want my windows broken either.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5512
any of those subs would be good, provided you can supply enough power to drive one.
I'[d go with a ported box in your case, and a single 12"
