System
Username: Ghost
Sharpsburg, Ga United States
I bought a 2005 cavalier and I don't want to take the factory cd player out I was told that I can by a speaker to RCA hook up and connect it to my rear deck speakers run it to my amp hook the power cord up run my remote wire from the remote slot on the amp to the power slot on the amp and go from amp to subs will that work.
Username: Carguy
Post Number: 54
Hey Daniel, yes it'll work. Almost every amp comes with that kit (speaker input to rca). If you're not too fussy with quality at high volumes then it's ok. I personally prefer to use the rca. If you're lucky, your factory HU might have a rca output connector, use that instead.
Username: Ghost
thank's but my amp doesen't say anything about that all it has is low input it's a really bogus amp it's a 1200 watt phoenix digital PD-395 2 channel it say's bass boost LPF + HPF will it still work what exactly do I have to do
Username: Joe718
Brooklyn, NY
Post Number: 187
the piece you need is called an adjustable line output converter.
Username: Carguy
Post Number: 63
You can buy that from almost any car stereo store.
