Sony XSL121P5 with which amp?
I'm looking at getting 2 12" Sony Subwoofers XSL121P5. These say they handle 1200 watts peak, 350 watts RMS. I've seen these matched with the Sony 2-Channel Amplifier XM2200GTX which handles
200 watts RMS x 2 @ 4 ohms or 1200W peak. So my question is this a good setup or should i get a amp that is 350 rms?thanks!!
Jason
Username: Matt77
OK US
Post Number: 31
he1l no stay away from sony
MustangObsesed
So for $400 what would you get? I have a friend that has that setup and i think it sounds good. What do you suggest i get? thanks!
Jason
Username: Deathshadow
Post Number: 163
LOL Stay away from Sony dude they will - XPLODE!!!
MustangObsesed
ok so if everyone says stay away...Then please guide me on what to get???
Username: Symplestiles
Stockton, CA Usa
Post Number: 235
for 400$ for amp + subs you cant do a whole lot.. but you can do 2 12" VMAXs w/ a JBL bp600.1 subs will run $89 a piece and the bp600.1z is $200 refurb. right now isnt it? that would be a much better buy than the sonys you are considering..also take into consideration with a bigger amp you might need a new alternator..which would be another 150-200$ its all a matter of how much time and money you want to put into it. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13950 check this site out. look at the kicker comps as well, they are around the same price as the vegas.
MustangObsesed
OK i'll check out those subs...What is your opinion on these Rockford fosgates? http://www.bestbuy.com/site/olspage.jsp?id=1074787610050&skuId=6302976&type=prod uct
mattjk
I personally reckon sony are cool from my experience, an ideal amp to run 2 of these is one of the class D range idealy if you have enough power try the Sony XMD1000P5 or if you dont want to upgrade the battery etc... go for the Sony XMD400P5 it pounds lol
