Best amps for X.XX
Username: Alex711
Post Number: 42
What's the best amp or amps for 2 12' RE X.XX for under $1000
Username: Sancho886
El Cajon, CA US
Post Number: 32
earthquake phd3
Username: Decde
Post Number: 206
Wolf uses 3 Orion 2250SX amplifiers for his 2 re's
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5462
well, you want to feed those subs 1000-1500 watts each of clean continuous power if you really want them to move.
Doing that is pretty much best done with a dedicated amp for each sub.
the RE triple X comes standard as a dual 2 ohm coil model, but you can special order them in dual 4 ohm as well to get a 2 ohm load for each mono amp.
in my case the dual 2s worked fine since each of my amps are bridged.
Username: Alex711
Post Number: 43
so what's a good amp for each of them that will push that much for a reasonable price??
Username: Glasswolf
Post Number: 5477
an MTX 1501D perhaps?
if you went with one amp per sub, and opted for the dual 4 ohm coil models..
you'd feed the subs 1500 watts each
the JBL bp1200.1 would do, too.
in any event, be sure your charging system is up to the task for that much current draw.
Username: Document_c
NY
Post Number: 29
ED Nine.1
Username: Alex711
Post Number: 44
So if i get 2 MTX 1501D's i should get the dual 4 ohm model?
Username: Alex711
Post Number: 45
hey Glass would 2 Orion 2500D amps be real good for the subs??
Username: Glasswolf
Post Number: 5488
that amp would work, too.
just match the amp's power @ load to the load of the sub(s) based on the coils, and how you'll wire them up.
