Like
Ok everyone i know what i want, now i need help wiring it.
Username: Bigap15
Post Number: 25
Im getting 2 Kicker comp Vr 10" subs. Im getting a Soundstream picasso amp rated at 300 x 2 rms @ 2 ohm, 600 x 1 rms @ 4 ohm. The subs can be either DVC 2ohm or DVC 4ohm. Which should i get and which way should i wire them. Diagrams will be appreciated. thanx
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5430
you'll want the dual 4 ohm coil versions of the CVR10 subs
wiring coils in parallel will give you a pair of 2 ohm subs.
put one sub on each channel and you'll get 300 watts per sub
all set
Username: Carguy
Post Number: 24
What glasswolf said is the best choice but if you ever want to get 600W x 1, then 2 ohm DVC is the one to get.
Username: Bigap15
Post Number: 26
thanx guys
does anyone here know any thing about that amp, is it any good
Username: Bigap15
Post Number: 27
thanx guys
its the soundstream pic2.600 2 channel amp, 300 x 2 rms at 2 ohm
Facebook
Shop Related Deals
Directory
