2 15" Brahmas...Need Amp Fast!!!
insearchofanamp
hey guys im on a very low budget...been savin up for 2 15" brahmas...well now im lookin at the JBL 1200.1 is there any way to wire this to get the desired 2 ohm load...or 1 ohm, and second is this enough power to power 2 15" brahmas...box is about 6 cubic feet total...bout 3 to each tuned to about 30 hz??? thanks!!!
Username: Decde
Post Number: 217
I doubt one amp can power those two brahma's. they are 1500 watts rms each. You will be wanting to feed them at least 1k each. If u check out, i think the zapco amps are a good match
Username: Boopers
Lima, Ohio United states
Post Number: 260
probably get 2 bp1200.1's for the price of 1 zapco
