Like
Car Audio Question.....
Username: Jtw320
Saginaw, MI
I recently bought two used 12-inch Kicker CVR's in a sealed box and I need to buy a amplifier. I dont know if they are the Dual 2-Ohm or Dual 4-Ohm Voice Coil Component Subs. Does anyone know how I can tell? And im thinking about buying the JBL BP600.1 amp, would this be a good choice for these subs?
Damien Rob.
Well if there are two positive and two negative leads on the sub they are DVC and if there is only one pair it's SVC.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5449
all CVR subs are dual coil.
they come in dual 2 and dual 4 ohm models.
take tone sub out of the box and look at the magnet to see what it says, or measure with a DMM for resistance. the DC load will be a bit lower than the nominal impedance. a 4 ohm coil usually reads about 3.6 ohms with a meter.
Username: Jtw320
Saginaw, MI
alright i took out the sub and it said dual 2 ohm voice coils. Would the JBL BP600.1 amp be good to power two of these subs? also any suggestions on how to wire the subs to the amp I know the amp has two sets of positive and negative connections, would I use one of the connections for one of the subs and the other for the other sub? diagrams? Thanks.
Username: Deven19
where do i hook up the REM to
Facebook
Shop Related Deals
Directory
