Mono-block amp with 2 outputs???
iheartbass
i was kind of confused because my amp is a mono classd amp but its got two speaker outputs. so my question is if i have a dual voice coil sub do i HAVE TO wire each coil to each terminal or can i wire both coils to the same terminal to make it easier to connnect the box since it only has one sub?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5408
you use a short set of wires to jumper the DVC coils together.
wire the sub to one set of amp terminals.
both sets of terminals are in parallel. it just makes wiring two subs easier.. that's all.
it's in the manual.
