RMS Ratings??
How do you calculate how many watts rms a amp is putting out?Volts and the fuses on the amp?EX:14.4v x 60A=864watts rms, is this right?
Username: Jonathan_f
GA USA
Post Number: 2539
Nope, that doesn't work. The amp will only be so efficient, and that cannot be calculated by fuse value. If you want to test the true power, you'll need a voltmeter on hand, and a resistor for an impedance load. Use the instructions here:
http://www.bcae1.com/measpwr.htm
Well that is what you said in one of your post(Archive through June 30;12" volfenhag;7 post)I just thought that it was right since you posted it.
GA USA
Post Number: 2543
When I said that, it was mainly to prove that certain cheap amps are in no way capable of producing the peak powers they claim, but it also doesn't take transformers into account. It balances out when efficiency is factored in. Anyway, the above is the proper way to measure RMS.
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1044
rough way to measure average RMS power is to multiple amps drawn by voltage level used
also to factor in effeciency, class D ~80%, class AB ~60%
